Customize GUI by user group?
  • samweber
    • Jan 2017
    We currently run Zabbix 2.0.3.
    We have a population of widgets we monitor. Suppose each widget has 10 triggers. I have two interested groups of users, the first group is interested in the first 5 triggers and the second groups is interested in the last 5. Is there a way to use the group membership of a user to tailor the triggers seen by that user? That way, each group sees only the data they are interested in.
  • batchenr
    • Sep 2016
    • 440
    i dont know about a way to give users the same host permissions but different triggers view -
    i can suggest you to clone the host- just change its name
    and to 1 you assign 5 types of triggers and the other the remaining 5 and to
    each user you give different host premonition.
    as you can clon zabbix host with same IP but not the same name.
    if we where talking about Email\SMS Alerts then we could filter this more easy.
    for example giving 1 Group 5 triggers that will mark as "HIGH" and the other group as "DISASTER" and set each group to get her own triggers.
    hope it helps.
