Zabbix SaltStack API
  • BanditoSs007
    • Aug 2024
    I'm currently trying to integrate Zabbix with SaltStack. Through API commands I'm creating hostgroups, guests... etc. I pull host data from the pillar.
    Everything is working OK, the problem is when I change a value in the pillar, the hosts are not updated. I would like to synchronize the data from the pillar and the guests on the Zabbix server.
    Has anyone done something similar? Can this be solved some other way than hardcoding?
    Thank you for any answers
