upgrading timescaledb
  • hakanozanlagan
    • Nov 2021
    • 35
    hi,
    I upgraded Zabbix from 6.0 LTS to 7.0 LTS. now zabbix getting below error and stop working.is there a guide for upgrading timescaledb for zabbix?
    4195:20240814:133016.165 TimescaleDB version 20601 is not officially supported. Recommended version is at least TimescaleDB Community Edition 2.13.0.
    4195:20240814:133016.169 Zabbix Server stopped. Zabbix 7.0.2 (revision d1b0c3308ce).
    my first timescaledb installation procedure for zabbix is below
    --install timescaledb
    apt install -y gnupg postgresql-common apt-transport-https lsb-release wget
    /usr/share/postgresql-common/pgdg/apt.postgresql.org.sh
    echo "deb https://packagecloud.io/timescale/timescaledb/ubuntu/ $(lsb_release -c -s) main" > /etc/apt/sources.list.d/timescaledb.list
    wget --quiet -O - https://packagecloud.io/timescale/timescaledb/gpgkey | sudo sh -c "gpg --dearmor > /etc/apt/trusted.gpg.d/timescaledb.gpg"
    apt -y update
    apt-get install -y timescaledb-2-postgresql-14='2.6.1*' timescaledb-2-loader-postgresql-14='2.6.1*'
    sudo timescaledb-tune --quiet --yes
    systemctl restart postgresql
    systemctl status postgresql
    --create extension
    psql
    \c zabbix
    CREATE EXTENSION IF NOT EXISTS timescaledb CASCADE;​
    --apply sql file
    cat /usr/share/zabbix-sql-scripts/postgresql/timescaledb.sql | sudo -u zabbix psql zabbix
    • 4993
    If you already had it installed, then installing update and then issuing "ALTER EXTENSION timescaledb UPDATE;" should do the trick... https://docs.timescale.com/self-host...minor-upgrade/
  • hakanozanlagan
    • Nov 2021
    • 35
    hi cyber. I finished upgrade at zabbix that have a small db.It is done quickly. but our prod env has 75GB database and it's taking very long time at applying schema sql.
    Is it neccesary to apply schema.sql? or do tou have any suggestion for better perofrmance
    my procedure is below.
    1. upgrade postgresql14 timescaledb from 2.06 to 2.15
    3. upgrade zabbix to 6.4 and 7.03 in order. and start with "AllowUnsupportedDBVersions=1" parameter
    4. install postgresql16 and timescaledb 2.15 on same machine
    5. migrate old db to v16
    6. apply schema.sql
    7. start zabbix server
      • 4993
      If you migrate your old db, you do not need to apply any sql any more (you will screw up your upgrade that way)... first startup of your server should do the upgrades and changes to schema.
      • hakanozanlagan
        • Nov 2021
        • 35
        thanks for answer
        Actually, I did not migrate database. An upgrade was made.. The command I used to upgrade the DB is below. After this command was completed on two different Zabbix servers, I ran schema.sql. They are now working without any problems. I read somewhere that when you upgrade to Zabbix 7.0, schema.sql needs to work in order for the table and schema infrastructure to be compatible. is it wrong?
        /usr/lib/postgresql/16/bin/pg_upgrade --old-datadir=/etc/postgresql/14/main/ --new-datadir=/PostgresqlData/ --old-bindir=/usr/lib/postgresql/14/bin --new-bindir=/usr/lib/postgresql/16/bin
        using schema.sql is neccesary if you use timescaledb.
        https://www.initmax.com/wiki/zabbix-...rsion-7-0-lts/
        "Since our Zabbix database uses the TimescaleDB extension, we must also run an SQL script again to initialize hypertables. A new feature in version 7.0 is the hypertabled auditlog table."
          • 4993
          ah .. I see.. it is a bit different approach to DB upgrade (not just zabbix DB schema) and data transfer...I think I will have an opportunity to do inplace upgrade soon, then I can see, if that reapply of schema is needed or not... From my current understanding, it shoudl not be necessary... but, who knows..
