Combine CPU graphs into one
  • Mechanix
    • Jan 2017
    • 92
    we have a couple of juniper switches with dual core cpu´s . How can I combine those individual graphs into one.
    The name of the item is
    Switch {#SNMPVALUE} - 5 min load avarage
    and the OID:
    .1.3.6.1.4.1.2636.3.1.13.1.21.9.{#SNMPVALUE}.0.0
    Now the graphs are created upon discovery but for every cpu separately. Any help is appreciated. Thank you
  • Semiadmin
    • Oct 2014
    • 1625
    Graph multiple LLD items on the same chart. Contribute to sepich/glld development by creating an account on GitHub.
    Also you may use Grafana + Zabbix plugin
    • Mechanix
      • Jan 2017
      • 92
      Thank you I´ll give it a try.
      • Pada
        • Apr 2012
        • 236
        With Zabbix 3.2 you can create graphs on the fly with multiple items when you navigate to Monitoring > Latest Data. You simply select all the items you want to graph (most likely apply a Filter at the top first) and then press the "Display graph" button.
        Unfortunately this is not something you'll want to use often, since its a fair amount of effort to do.
        • Mechanix
          • Jan 2017
          • 92
          Hi, thx for your reply.
          Yes, this helps me a lot as I do need to display the graphs only on request.
          Cheers,
          C.
