Zabbix Speed FAN
  • jagrok
    • Mar 2016
    Zabbix Speed FAN
    I`m really new in Zabbix and i`m really confused about creating some condition in zabbix.
    I would like to create trigger which will monitor RPM of FAN.
    Normal value of this work is 10.000 rpm warning value will be 8.000 rpm and danger will be 4.000 rpm
    How can i add some exception if FAN is not working and it`s speed is 0 rpm (it`s possible and it`s not fault)
  • batchenr
    • Sep 2016
    • 440
    i think you should use this :
    and then you set the trigger with {ITEM.VALUE} so each response will show different output - all with 1 item and 1 trigger.
    • jagrok
      • Mar 2016
      Thank You,
      I went for the other solution and i`ve created trigger with and statment.
      {<server>:<key>.<function>(<parameter>)}<1500 and {<server>:<key>.<function>(<parameter>)}<>0
