RDP collection failed
  • Glauber55
    • Mar 2023
    • 11
    Good afternoon !
    I'm new to the zabbix world, I'm trying to collect the RDP sessions from the server and I'm not able to obtain the collection data in my zabbix. In my research I found documentation teaching step by step, but nothing works correctly.
    Link: https://github.com/iSmartyPRO/zabbix...rdp_monitoring
    thank you !
  • Answer selected by Glauber55 at 21-08-2024, 05:51.
    vijayk
    • May 2023
    • 305
    Glauber55 Please check with below key if it works in version 6.2. I'm running with 7.0 and its working perfect.
    • vijayk
      • May 2023
      • 305
      Which version of Zabbix server and agent are you using?
      • Glauber55
        Glauber55 commented
        Server:
        zabbix_server (Zabbix) 6.2.6
        Agent:
        Starting Zabbix Agent [RADAR]. Zabbix 6.0.32
    • Glauber55
      • Mar 2023
      • 11
      I have performed the following steps as per the documentation and images attached now.
      But it didn't work.
      After installation, copy the folder C:\Users\YourUser\Documents\WindowsPowerShell\modu les\PSTerminalServices\
      Paste the PSTerminalServices folder into C:\Windows\System32\WindowsPowerShell\v1.0\Modules \
      Is there another easier way for me to collect RDP Windows Server 2012 sessions?
      • Brambo
        • Jul 2023
        • 250
        I believe you can get the who is logged in by running:
         query user /server:Localhost
        Not sure if it works on user level or that you need admin.
        With a discovery rule you can than monitor every user who was logged in or not State active is logged in, Disconnected is not connected but also didn't use logoff ...
        Then create a calculated item which calculated every State Active and you have best of all worlds
        • vijayk
          • May 2023
          • 305
          • t00m1G
            • Jan 2024
            • 26
            Originally posted by Glauber55
            Good afternoon !
            thank you !
            Hey,
            What template are you using for that host? This provided on linked GitHub repo?
            • Glauber55
              • Mar 2023
              • 11
              Originally posted by t00m1G
              Hey,
              yes correct, I am using the same template provided from the GitHub repository for this host.
              • t00m1G
                • Jan 2024
                • 26
                Glauber55
                So I think issue might be here, as I can see this template uses some of I think non compatible keys in it,
                Please try changing keys to those:
                Active users: from "rdp.terminal.server[ACTIVE]" change it to: perf_counter[\Terminal Services\Active Sessions]
                Inactive users: from "rdp.terminal.server[INACTIVE]" change it to: perf_counter[\Terminal Services\Inactive Sessions]
                I've got them from perfmon.msc, but since I do not have instance of win2012 around me I have only those two which I've gathered from Win11.
                please check if changing those two will make any difference.
