copy / clone triggers to other instance
  • mazdajai
    • Mar 2016
    • 9
    Is there a way to clone triggers to other instance of zabbix?
    I have been searching in the forum and internet but couldn't find much on it.
  • nobodysu
    • Sep 2016
    • 84
    You should use templates explicitly, thus you can manage your triggers (and else) easily.
    • mazdajai
      • Mar 2016
      • 9
      Sorry for the confusion. I mean the triggers, under actions.
      • batchenr
        • Sep 2016
        • 440
        to clon to another machine you need to copy the item and then the trigger
        • mazdajai
          • Mar 2016
          • 9
          I am referring to Actions > Event Source - Triggers. NOT the triggers for the hosts.
          • batchenr
            • Sep 2016
            • 440
            so you mean an alert ?
            but why duplicate it ? you can add the host you want to this event.
            if you need another just create new one.
            if you get in this action you will have a clon button- if you mean another zabbix server then just copy past
            or ealse i really dont understand what you want to do.. sorry.
