Discovery of multiple ips for a single host
  • robert.s
    • Nov 2021
    I've been using Zabbix for a while and currently on version 7.0.2. I'm trying to figure out how to add multiple IPs from different subnets to the same host using discovery. Specifically, I'm working with Mikrotik routers that broadcast their IPs via SNMP in the OID .1.3.6.1.2.1.4.20.1.1.
    I can successfully add IPs from a single subnet to a host using a rule and action that groups interfaces under the same host if they share the same name. However, I'm looking to extend this to include IPs from other subnets, like internal IPs (e.g., 10.0.0.0), for the same device.
    Using this Discovery Rule
    Click image for larger version  Name:	image.png Views:	0 Size:	37.3 KB ID:	489878
    and this discovery Action
    Add discovered routers Discovery rule equals Mikrotik Routers
    Discovery status equals Up
    Add host
    Add to host groups: Routers
    Remove from host groups: Discovered hosts
    Link templates: Generic by SNMP, Mikrotik by SNMP
    Set host inventory mode: Automatic
  • t00m1G
    • Jan 2024
    • 26
    Hey,
    So, your end goal is to automatically discover every IP of every interface on your router?
    I'm asking because I'm not sure what do you mean, and what is your end goal.
