Trigger expression after 2min or 5 values
  • TomWuyts
    • Nov 2023
    I have this problem expression in my trigger. The problem is that I have falso positives, I get often an alarm but the connection isn't down.
    How can I adjust the trigger to only sent an alarm if the connection is down for longer than 2 minutes? Or last 5 values?
    {$SDWAN.MEMBER.IF.CONTROL:"{#NAME}"}=1 and last(/FortiGate by HTTP-FGT600E/fgate.sdwan_member.link_status[{#ID}])=1 and (last(/FortiGate by HTTP-FGT600E/fgate.sdwan_member.link_status[{#ID}],#1)<>last(/FortiGate by HTTP-FGT600E/fgate.sdwan_member.link_status[{#ID}],#2))
    1 is down and 0 is up?
    so instead of "last" you should evaluate over time, using functions like max/min
    min(/FortiGate by HTTP-FGT600E/fgate.sdwan_member.link_status[{#ID}],#5)>0
    Minimum value during last 5 checks is higher than 0. essentially meaning all 5 values are not 0
    min(/FortiGate by HTTP-FGT600E/fgate.sdwan_member.link_status[{#ID}],2m)>0
    Similar, but evaluation is time based, 2 minutes.
    I guess both of them make the last part (last value not equal to next to last) not needed any more...
