cannot connect to 127.0.0.1:10051
  • mario_rossi
    • Jun 2024
    • 15
    I'm having problems connecting the windows machine with active agent to the zabbix server. I receive the following errors in the .log file
    2024/08/22 20:02:49.734818 Zabbix Agent2 hostname: [HQ]
    2024/08/22 20:02:50.739746 [101] cannot connect to [127.0.0.1:10051]: dial tcp :0->127.0.0.1:10051: connectex: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione.
    2024/08/22 20:02:50.739746 [101] active check configuration update from host [HQ] started to fail
    2024/08/22 20:02:50.739746 [101] sending of heartbeat message for [HQ] started to fail
    Can you help me solve the problem?
  • Answer selected by mario_rossi at 29-08-2024, 10:08.
    Markku
    • Sep 2018
    • 1781
    Zabbix agent is not correctly configured with ServerActive directive as it is trying to connect to localhost (127.0.0.1) instead of your Zabbix server.
    Or, you need to restart the agent after changing the configuration file.
    Markku
    • idkmyusername
      • Aug 2024
      Did you open port 10051 in firewall on that Windows machine?
      • Markku
        • Sep 2018
        • 1781
        Markku
        • yylinnn
          • Aug 2024
          Maybe you should paste the config of zabbix agent
          • mario_rossi
            • Jun 2024
            • 15
            Hi guys, thanks so much for your help. It was a configuration error with the active server, it was not configured correctly.
            Thanks, problem solved.
            • robin_bolli
              • Jan 2025
              • 9
              Hi Mario,
              I believe I have the same issue with my Zabbix server. Could you please tell me how you solved it?
              Thank you!
              Best regards,
              Robin
              • robin_bolli
                robin_bolli commented
                Solved, i forgot to set StartVMwareCollectors=1
            • ModularConfusion
              • Apr 2024
              • 23
              Having the same issue. There is a proxy running on localhost, so I do want it to connect to localhost. However, there are numerous proxies here in a proxy group, so my guess is this is the issue.
