Unsupported charset or collation for tables warning after upgrade from 6.0 to 6.4
  • yylinnn
    • Aug 2024
    Just upgrade zabbix from 6.0 to 6.4. Everything looks like good.
    But there is a warning in System Infomation: Unsupported charset or collation for tables: scim_group, userdirectory, connector, userdirectory_media, userdirectory_saml, connector_tag, userdirectory_ldap, userdirectory_idpgroup.
    My mariaDB version is: Server version: 10.9.3-MariaDB-1:10.9.3+maria~ubu2004
    setting of collation is:
    MariaDB [(none)]> SELECT @@character_set_database, @@collation_database;
    | @@character_set_database | @@collation_database |
    | utf8mb4 | utf8mb4_general_ci |
    1 row in set (0.000 sec)
    and I tried to alter :
    [I]alter database zabbix  character set utf8mb4 collate utf8mb4_bin;[/I]
    but nothing changed, the @@collation_database is still "utf8mb4_general_ci"
    Is anyone has suggestion?
  • Answer selected by yylinnn at 27-08-2024, 09:33.
    tim.mooney
    • Dec 2012
    • 1436
    Even the Zabbix documentation that you found isn't very clear. The system variable @@collation_database is updated whenever you connect to a specific database, to reflect the settings for that database. The Zabbix doc you reference doesn't seem to say it currently, but you need to be connected to the 'zabbix' database to get the settings for it. Watch:
    MariaDB [(none)]> SELECT @@collation_database;
    | utf8_unicode_ci      |
    MariaDB [(none)]> use zabbix;
    Reading table information for completion of table and column names
    You can turn off this feature to get a quicker startup with -A
    Database changed
    MariaDB [zabbix]> SELECT @@collation_database;
    | utf8_bin             |
    I typically use the "SHOW CREATE" family of commands when I want to get information about how a database or table or whatever actually was created.
    In your case, I suspect you're going to find that once you've connected to your 'zabbix' database it is now using the correct collation, so future table creation will inherit that, but you have a few older tables that are using the wrong setting. Altering the database doesn't alter those tables. You need to fix each of them too.
    • yylinnn
      yylinnn commented
      thank you very much.
      finally , the problem is sloved. I update the table with SQL like
      MariaDB [zabbix]> ALTER TABLE host_rtdata CONVERT TO CHARACTER SET utf8mb4 COLLATE utf8mb4_bin;
      Query OK, 0 rows affected (0.005 sec)
      Records: 0 Duplicates: 0 Warnings: 0​
      thanks a lot
  • yylinnn
    • Aug 2024
    I found a doc “Repairing Zabbix database character set and collation”
    and tried follow the step to
    but nothing changed, the @@collation_database is still "utf8mb4_general_ci"​
    • tim.mooney
      • Dec 2012
      • 1436
      | utf8_unicode_ci      |
      Database changed
      | utf8_bin             |
      • yylinnn
        yylinnn commented
        thanks a lot
    • yylinnn
      • Aug 2024
      Yes, you are correct. Thank you very much.
      I checked the zabbix database, it's already in right collation
      MariaDB [zabbix]> SELECT @@character_set_database, @@collation_database;
      | utf8mb4 | utf8mb4_bin |
      MariaDB [zabbix]>
      Then ,the next step is to correct these table's collation.
      MariaDB [zabbix]> SELECT TABLE_NAME, CCSA.CHARACTER_SET_NAME AS table_charset, CCSA.COLLATION_NAME AS table_collation FROM information_schema.`TABLES` T, information_schema.`COLLATION_CHARACTER_SET_APPLIC ABILITY` CCSA WHERE CCSA.COLLATION_NAME = T.TABLE_COLLATION AND T.TABLE_SCHEMA = 'zabbix' and table_collation = 'utf8mb4_general_ci';
      | TABLE_NAME | table_charset | table_collation |
      | scim_group | utf8mb4 | utf8mb4_general_ci |
      | userdirectory | utf8mb4 | utf8mb4_general_ci |
      | changelog | utf8mb4 | utf8mb4_general_ci |
      | host_rtdata | utf8mb4 | utf8mb4_general_ci |
      | connector | utf8mb4 | utf8mb4_general_ci |
      | user_scim_group | utf8mb4 | utf8mb4_general_ci |
      | userdirectory_media | utf8mb4 | utf8mb4_general_ci |
      | userdirectory_saml | utf8mb4 | utf8mb4_general_ci |
      | userdirectory_usrgrp | utf8mb4 | utf8mb4_general_ci |
      | event_symptom | utf8mb4 | utf8mb4_general_ci |
      | connector_tag | utf8mb4 | utf8mb4_general_ci |
      | userdirectory_ldap | utf8mb4 | utf8mb4_general_ci |
      | userdirectory_idpgroup | utf8mb4 | utf8mb4_general_ci |
      13 rows in set (0.002 sec)​
