Debug LLD with trapper item prototype
  • linbo
    • Jan 2017
    In my test environment I try to setup lvs monitor with zabbix LLD.
    Zabbix 3.2.0
    OS: Ubuntu 14.04.1 LTS
    # Discovery rule
    1. key: lvs.service
    2. Type: Zabbix agent
    3. Two Filters with empty regular expression
    {#SERVICE_HOST}
        {#SERVICE_PORT}
        # cat /etc/zabbix/zabbix_agentd.conf.d/userparameter_lvs.conf
        UserParameter=lvs.service, python /etc/zabbix/script/lvs_monitor/dump_service.py
        # python /etc/zabbix/script/lvs_monitor/dump_service.py
        {"data": [{"{#SERVICE_HOST}": "10.211.55.12", "{#SERVICE_PORT}": "7777"}, {"{#SERVICE_HOST}": "10.211.55.11", "{#SERVICE_PORT}": "7778"}]}
    # Item prototypes 1 works fine
    Key: net.tcp.service[tcp,{#SERVICE_HOST},{#SERVICE_PORT}]
    Type: Zabbix agent
    # Item prototypes 2 doesn't work, no item created in Configuration -> Hosts -> Items page
    Key: lvs_service[inbps,{$SERVICE_HOST},{$SERVICE_PORT}]
    Type: Zabbix trapper
    A crontab use zabbix_sender to send data to zabbix_server
    # cat /tmp/lvs_service_stat
        precise64 lvs_service[inpps,10.211.55.12,7777] 1485221745 0
        precise64 lvs_service[inpps,10.211.55.11,7778] 1485221745 0
    In zabbix console, discovery rule show error:
    Cannot create item: item with the same key "lvs_service[inbps,{$SERVICE_HOST},{$SERVICE_PORT}]" already exists.
    After some time, the error message missing, and Zabbix Server log
    trapper got '{
            "request":"sender data",
            "data":[
                    "host":"precise64",
                    "key":"lvs_service[inpps,10.211.55.12,7777]",
                    "value":"0",
                    "clock":1485221821},
                    "host":"precise64",
                    "key":"lvs_service[inpps,10.211.55.11,7778]",
                    "value":"0",
                    "clock":1485221821}],
            "clock":1485221821}'
         16152:20170124:093701.030 In recv_agenthistory()
         16152:20170124:093701.030 In process_hist_data()
         16152:20170124:093701.030 In process_mass_data()
         16152:20170124:093701.031 End of process_mass_data()
         16152:20170124:093701.031 End of process_hist_data():SUCCEED
         16152:20170124:093701.031 In zbx_send_response()
         16152:20170124:093701.031 zbx_send_response() '{"response":"success","info":"processed: 0; failed: 2; total: 2; seconds spent: 0.000102"}'
    How to debug LLD issue?
    Thanks,
    Linbo
  • nobodysu
    • Sep 2016
    • 84
    needs to be
    Key: lvs_service[inbps,{#SERVICE_HOST},{#SERVICE_PORT}]
    • linbo
      • Jan 2017
      Thank you.
      I correct the key name, now item show in zabbix console without issue. But still no data.
      precise64 lvs_service[inpps,10.211.55.12,7777] 1485390541 0
      precise64 lvs_service[inpps,10.211.55.11,7778] 1485390541 0
      # zabbix_sender -z 10.211.55.4 -T -i /tmp/lvs_service_stat -vv
      zabbix_sender [13922]: DEBUG: answer [{"response":"success","info":"processed: 0; failed: 2; total: 2; seconds spent: 0.000102"}]
      Info from server: "processed: 0; failed: 2; total: 2; seconds spent: 0.000102"
      sent: 2; skipped: 0; total: 2
      The zabbix server log:
       2146:20170126:082958.280 In substitute_key_macros() data:'lvs_service[inbps,{#SERVICE_HOST},{#SERVICE_PORT}]'
        2146:20170126:082958.280 In substitute_lld_macros() data:'{#SERVICE_HOST}'
        2146:20170126:082958.280 End of substitute_lld_macros():SUCCEED data:'10.211.55.11'
        2146:20170126:082958.280 In substitute_lld_macros() data:'{#SERVICE_PORT}'
        2146:20170126:082958.280 End of substitute_lld_macros():SUCCEED data:'7778'
        2146:20170126:082958.280 End of substitute_key_macros():SUCCEED data:'lvs_service[inbps,10.211.55.11,7778]'
        2146:20170126:082958.280 End of substitute_lld_macros():SUCCEED data:'10.211.55.12'
        2146:20170126:082958.280 End of substitute_lld_macros():SUCCEED data:'7777'
        2146:20170126:082958.280 End of substitute_key_macros():SUCCEED data:'lvs_service[inbps,10.211.55.12,7777]'
        2146:20170126:082958.280 In substitute_key_macros() data:'net.tcp.service[tcp,{#SERVICE_HOST},{#SERVICE_PORT}]'
        2146:20170126:082958.280 End of substitute_key_macros():SUCCEED data:'net.tcp.service[tcp,10.211.55.11,7778]'
        2146:20170126:082958.281 In substitute_lld_macros() data:'{#SERVICE_PORT}'
        2146:20170126:082958.281 End of substitute_lld_macros():SUCCEED data:'7777'
        2146:20170126:082958.281 End of substitute_key_macros():SUCCEED data:'net.tcp.service[tcp,10.211.55.12,7777]'
        2146:20170126:082958.281 In lld_item_update()
        2146:20170126:082958.281 In substitute_lld_macros() data:'LVS Service $2:$3 status'
        2146:20170126:082958.281 End of substitute_lld_macros():SUCCEED data:'LVS Service $2:$3 status'
      2153:20170126:082959.375 __zbx_zbx_setproctitle() title:'trapper #4 [processing data]'
        2153:20170126:082959.375 trapper got '{
          "data":[
                  "host":"precise64",
                  "value":"0",
                  "clock":1485390541},
                  "host":"precise64",
                  "value":"0",
                  "clock":1485390541}],
          "clock":1485390599}'
        2153:20170126:082959.375 In recv_agenthistory()
        2153:20170126:082959.375 In process_hist_data()
        2153:20170126:082959.375 In process_mass_data()
        2153:20170126:082959.375 End of process_mass_data()
        2153:20170126:082959.375 End of process_hist_data():SUCCEED
        2153:20170126:082959.375 In zbx_send_response()
        2153:20170126:082959.375 zbx_send_response() '{"response":"success","info":"processed: 0; failed: 2; total: 2; seconds spent: 0.000096"}'
        2153:20170126:082959.375 End of zbx_send_response():SUCCEED
        2153:20170126:082959.375 End of recv_agenthistory()
        2153:20170126:082959.375 __zbx_zbx_setproctitle() title:'trapper #4 [processed data in 0.000571 sec, waiting for connection]'
      • linbo
        • Jan 2017
        Sorry my bad, I use wrong key name, now fixed it and everything works fine.
        Thank you very much!
