Issues Connecting Zabbix to Grafana in Docker Network
  • SMS Cruz Machado
    • Aug 2024
Name:	Captura de tela 2024-08-28 105700.png
    Hello everyone,
    I'm currently running Zabbix and Grafana in Docker containers on the same network. However, I'm facing issues when trying to connect Zabbix to Grafana. Here are the details:
    • Setup: Both Zabbix and Grafana are running in separate Docker containers on the same Docker network.
    • Problem: When attempting to connect Zabbix to Grafana, I encounter various errors.
    Here are some specific errors and observations:
    1. I get a error when trying to access . This indicates that the endpoint might not be correctly configured or available.404 Not Foundhttp://172.19.0.4:8080/zabbix/api_jsonrpc.php
    2. I have tried various IP addresses and configurations to access the Zabbix API, but none of them work.
    3. I have tried different commands to test connectivity and endpoints, but I'm not getting the expected responses.curl
    I would appreciate any guidance or suggestions on how to resolve these connectivity issues and ensure that Zabbix and Grafana can properly communicate.
    Thank you in advance for your help!
  • rocky_like
    • Sep 2024
    Hello, i'm facing the same problem, did you got solve this ?
    • rocky_like
      • Sep 2024
      I just solved it, just put the URL as http://localhost/api_jsonrpc.php
      • batara
        • Aug 2024
        Hi SMS Cruz,
        Are you able to connect your zabbix to your grafana as data sources? , I have the same issue
        trying to access by using bellow url, but can't work.
        http://10.108.139.202:8080/api_jsonrpc.php >>> Error Application error. Incorrect user name or password or account is temporarily blocked.
        http://10.108.139.202:8080/zabbix/api_jsonrpc.php >>> request failed, status: 404 Not Found
        http://localhost:8080/api_jsonrpc.php >>> Post "http://localhost:8080/api_jsonrpc.php": dial tcp [::1]:8080: connect: connection refused
        http://localhost:8080/zabbix/api_jsonrpc.php >>> Post "http://localhost:8080/zabbix/api_jsonrpc.php": dial tcp [::1]:8080: connect: connection refused
        please kindly help for this issue everyone
