Creating a trigger for a text-based item
  • nasomers
    • Dec 2016
    Hello all!
    I have created an item for updates/packages for Linux systems, which returns a text list of the packages and respective version.
    I want to create a trigger that alerts when this item returns any text, but I can't get a trigger to work. I know that the item works as when I visit "Latest Data" I can see the text list of packages there.
    Thanks so much!
    Here's what I'm using for the item
    UserParameter=system.sw.debianupdates-list,apt-get dist-upgrade -s  |sed -n 's/^Inst \(.*\) (.*/\1,/p' | tr '\n' ' '
  • batchenr
    • Sep 2016
    • 440
    Originally posted by nasomers
    Hello all!
    Thanks so much!
    you can look at this direction -
    set the trigger with .nodata=0 or .nodata=1 for this item
    for me the easiest way is to create a bash script
    #!/bin/bash
    CHECK=$(apt-get dist-upgrade -s |sed -n 's/^Inst \(.*\) (.*/\1,/p' | tr '\n' ' ')
    if [[ -n $CHECK ]]; then
    echo 0
    else
    echo 1
    fi
    and then set the trigger like this :
    {server.office.local:system.sw.debianupdates-list.last(0)}=0
    and if the script returns 0 when the check command is not null it will fire a trigger
    • nasomers
      • Dec 2016
      Sorry, new to Zabbix. Could you expand on this a little? Thanks!
      • batchenr
        • Sep 2016
        • 440
        i never set a trigger for this but i think you can set a trigger like
        {server.office.local:system.sw.debianupdates.nodat a(600)}=0
        it will fire the trigger - but again im no expert either
        i will always prefer making my own scripts.
        • nasomers
          • Dec 2016
          Unfortunately I get an error trying to save that, says the trigger expression is invalid and cannot be used.
          • nasomers
            • Dec 2016
            I want the trigger to list the packages in the actual alert on the dashboard. I have it configured now to alert when there are updates available at all and how many, but I want to know what the packages are so I can discern if they may be service affecting or not.
            • batchenr
              • Sep 2016
              • 440
              you cant with the dash board because if you will have a
              long string it will cut a half of it.
