AWS EC2 instances discovery and Zabbix Agents set instance-id in HostnameItemin
  • mariano.obarrio
    • May 2022
    Good all, I am using the EC2 instances discovery tuned to create host prototypes with the private IP of the instance to be able to connect with the zabbix agents on them, but I have the problem that the zabbix server gives errors of all Zabbix Agents as “host [xxxx] not found” because the hosts are created with the instance-id of AWS. ... can you think of a way to make the zabbix agent set the HostnameItem= with the instance ID (e.g. i-0cc6a80fc032fdb35)... I try with system.run[] and a curl query to the APIPA address... the curl works in bash but inside the zabbix agent it doesn't...
    Can you think of any other way to solve this?
    Thxs,
    M.
