ODBC Low Level Discovery (MSSQL)
  • savianae
    • Jan 2017
    I have a zabbix installation with somes proxies 3.0.7.
    I am getting an error "Value should be a JSON object." . And I am unable to identify my problem.
    I have set the regex :
    Databases for discovery
    1	ยป	^(master|model|msdb|ReportServer|ReportServerTempDB|tempdb)$	[Result is FALSE]
    I have set the Value mapping
    	MS SQL Server database state	0 ⇒ ONLINE
    1 ⇒ RESTORING
    2 ⇒ RECOVERING
    3 ⇒ RECOVERY PENDING
    4 ⇒ SUSPECT
    5 ⇒ EMERGENCY
    6 ⇒ OFFLINE
    7 ⇒ Database Does Not Exist on Server
    Macro is set
    Macro		Effective value
    {$INSTANCE}    ⇒ INSTANCE1
    {$ODBC}           ⇒ MyDbHost
    {$PASSWORD} ⇒ myDbPassword
  • savianae
    • Jan 2017
    osql is working as the zabbix user :
    [CODE]
    osql -S VRINTDBSI05 -U 'domain\mon_user' -P 'xxxxx'
    checking shared odbc libraries linked to isql for default directories...
    strings: '': No such file
    trying /tmp/sql ... no
    trying /etc ... OK
    checking odbc.ini files
    reading /root/.odbc.ini
    [MyDbHost] not found in /root/.odbc.ini
    reading /etc/odbc.ini
    [MyDbHost] found in /etc/odbc.ini
    found this section:
    [MyDbHost]
    Description = MyDbHost
    Driver = FreeTDS
    ServerName = MyDbHost
    Instance = INSTANCE5
    TDS_Version = 7.4
    • savianae
      • Jan 2017
      looking for driver for DSN [MyDbHost] in /etc/odbc.ini
      found driver line: " Driver = FreeTDS"
      driver "FreeTDS" found for [MyDbHost] in odbc.ini
      found driver named "FreeTDS"
      "FreeTDS" is not an executable file
      looking for entry named [FreeTDS] in /etc/odbcinst.ini
      found driver line: " Driver = /usr/local/lib/libtdsodbc.so"
      found driver /usr/local/lib/libtdsodbc.so for [FreeTDS] in odbcinst.ini
      /usr/local/lib/libtdsodbc.so is an executable file
      Using ODBC-Combined strategy
      DSN [MyDbHost] has servername "MyDbHost" (from /etc/odbc.ini)
      cannot read "/root/.freetds.conf"
      /usr/local/etc/freetds.conf is a readable file
      looking for [MyDbHost] in /usr/local/etc/freetds.conf
      found this section:
      [MyDbHost]
      host = myIpAddress
      instance = INSTANCE5
      tds version = 7.4
      looking up hostname for ip address myIpAddress
      /usr/local/bin/osql: line 344: host: command not found
      osql: warning: no DNS hostname found for "myIpAddress"
      Configuration looks OK. Connection details:
      DSN: MyDbHost
      odbc.ini: /etc/odbc.ini
      Driver: /usr/local/lib/libtdsodbc.so
      Server hostname: myIpAddress
      Address: myIpAddress
      Attempting connection as MyDomain\mon_svc ...
      + isql MyDbHost 'MyDomain\mon_svc' myPassword -v
      | Connected! |
      | sql-statement |
      | help [tablename] |
      | quit |
      SQL> select '{"data":[', (SELECT STUFF((SELECT ',' + '{"{#DBNAME}":"' + [Name] + '"}' FROM master..sysdatabases ORDER BY [Name] FOR XML PATH('')), 1, 1, '')) ,']}' FOR XML PATH('')
      | XML_F52E2B61-18A1-11d1-B105-00805F49916B |
      | {"data":[{"{#DBNAME}":"MyDB1"},{"{#DBNAME}":"master"},{"{#D BNAME}":"model"},{"{#DBNAME}":"msdb"},{"{#DBNAME}" :"MyDB2 "},{"{#DBNAME}":"tempdb"},{"{#DBNAME}":"wiki"}]} |
      SQLRowCount returns 1
      1 rows fetched
      SQL>
      [/CODE]
      It seems I am not fare away ... but still not working.
      • savianae
        • Jan 2017
        http://jsonlint.com/ claims my JSON is valid :
        "data": [{
        "{#DBNAME}": "MyDB1"
        "{#DBNAME}": "master"
        "{#D BNAME}": "model"
        "{#DBNAME}": "msdb"
        "{#DBNAME}": "MyDB2 "
        "{#DBNAME}": "tempdb"
        "{#DBNAME}": "wiki"
        did I miss something ?
        • Pada
          • Apr 2012
          • 236
          The JSON does look OK to me too, however I'm not sure if its just a formatting issue when you pasted it into these forums, but the following doesn't look right to me:
          1. space in "{#DBNAME}":
          2. space after MyDB2:
          Also, can you run the 'isql' command from the zabbix user?
          Only other suggestion that I can make is to create a new item (not as a discovery rule) for that host with:
          Type = Database monitor
          Type of information = Text
          and then with the same SQL query that you have in your discovery
          Then have a look at the output that it produces in that item when you go under Monitoring > Latest data.
          One thing that it could also be is escaping of " or ' in Zabbix when it tries to perform the SQL query.
          • tym
            • Mar 2017
            Try this key, db.odbc.discovery[dbname,{$ODBC}]
            • tym
              • Mar 2017
              db.odbc.select work only for items
              • tym
                • Mar 2017
                Hola again sorry on my first post not full)
                Use key: db.odbc.discovery[name,{$ODBC}]
                SQL query: SELECT name FROM master..sysdatabases;
                and replace {#DBNAME} on {#NAME} in all items.
                but next time read manual on off site
