Hikvision camera by HTTP authentication issue
  • elias.st
    • Sep 2024
    Hi everyone
    I am trying Hikvision camera by HTTP template on one of my hikvision cameras. After configuration of SNMP community , username, password I am getting an "unauthorized" message on most of the items.
    I did a wireshark capture on the camera and zabbix is sending the HTTP request without any username or password. When I try to open the ISAPI Url of the camera using a browser such as
    http://cameraip/ISAPI/system/deviceinfo , I get a username and password prompt and then I see the XML data. This confirms that my camera setup and protocol is all correct.
    Any idea why Zabbix/Hikvision HTTP template doesn't authenticate the HTTP request despite filling the username and password correctly in the Macro ?
    Thanks !
  • Hamardaban
    • May 2019
    • 2714
    Try to understand the difference between SNMP and HTTP.….
    • markfree
      • Apr 2019
      • 875
      Zabbix integration page has instructions on how to setup this template, including authentication.
      • elias.st
        • Sep 2024
        Hi All
        Thanks for your responses.
        Its ok now, I managed to fix the problem. My configuration was all correct as per the instructions provided. I had to edit the template and changed the HTTP authentication from digest to basic for 3 items that are requesting the ISAPI HTTP request, Just sharing this if anyone else on the forums struggles with this authentication issue.
