Counters for printers
  • lordstahl
    • Sep 2024
    Good day. I'm trying to make print counters for printers - while I'm trying from HP. The indicator from which I can take data is only a counter that tells me how much the printer has printed, respectively, then everything is just formulas. For a week now, I've been puzzling over how to correctly write a formula for data for a day, week, month and year, for example. Through much work with the help of ChatGPT, I have so far come to two formulas max(//printer.total.printed.pages,1d) - min(//printer.total.printed.pages,1d) and the second one last(//a4total.device)-last(//a4total_1d.device,#1) printer.total.printed.pages in the first one is an indicator from the SNMP of all prints. a4total.device is the same thing, but a4total_1d.device also takes it from SNMP, but at the same time it works with the Scheduling parameter - wd1-7h0m00 - that is, it seems to work out at the right time. chatgpt, of course, alas, does not understand a lot - sometimes it offered something like a formula with delta - delta(//printer.total.printed.pages[1d]) - but here the syntax is incorrect and I do not know if it works in my case at all? Actually, the question is - what is the difference between my two formulas and whether they can actually do calculations at all? Or maybe there are other options? Thank you in advance for your help
    • 5002
    max(,,1d)-min(,,1d) .. if that is evergrowing number, and you do that calculation in midnight, then you probably are going to get a number of prints per day, as smallest number was a day ago and it grew through the day ..
    last() and last(,#1) are identical things.. so last(//a4total.device)-last(//a4total_1d.device,#1)... I guess it might do the similar calculation, if that a4total_1d contains number form 1d ago...
    you can also use time shift in parameters.. last(/host/item)-last(/host/item,#1:now/d)
    • lordstahl
      • Sep 2024
      https://www.zabbix.com/documentation...ion#time-shift
      That is, as I understand it, in general, my formulas are identical and make the correct measurements?
      They can easily spread to the calculations of the month, half a year and a year - is there nothing to think about here?
        • 5002
        There is always something to think about... Meaning of life... next shopping list.. Where does money disappear and from where comes the dust...
