Zabbix Backend Database Migration - Oracle to PostgreSQL
  • akamagroboy
    • Sep 2020
    • 9
    Hello guys, how are you?
    I have a Zabbix installed in version 6.0 and we're planning the upgrade to version 7.0.
    I'm currently using Oracle Database as a Backend for my Zabbix environment.
    Since Oracle Backend Database is deprecated in version 7.0 and will be removed in future versions, do we have a migration tool or something like that?
    If not, if I install a PostgreSQL with version 6.0 and copy all table contents to the PostgreSQL from Oracle, that will work?
    Thanks in advance
    If all the tables have same structure on both types, then I dont see any reason why copying should not work ...
