Export/Import Zabbix Dashboards & Graphs between Multiple Zabbix Implementations
  • jburysom
    • Jun 2024
    • 16
    Hello there,
    I'm currently running two zabbix implementations, 7.0.3 in development and 6.4.14 in production. I need to move dashboards and graphs from production into development. Is there a way to export dashboards/graphs in zabbix version 6.4.14 and import them in zabbix version 7.0.3. I'm hoping I do not have to re-create each dashboard/graph by hand. I was hoping there was an easier way.
    Thanks,
    John
    • 5002
    https://www.zabbix.com/documentation.../dashboard/get API calls most probably. But most probably your host/item ID-s wont match between those instances, so it will screw it up anyway...
