For graphs and maps, TrueType fonts are used.
Even when using Japanese, it is not displayed properly by default.
By switching to a font that can be displayed in Japanese as a font used in graph display, it can be displayed normally.
Also in Thai language, I think that you can display normally if you switch to a font that can display Thai language.
If you are using packages for RHEL or CentOS, you can use alternatives to change them.
If installing from the source, modify include/defines.inc.php of the web frontend.
(ZBX_GRAPH_FONT_NAME and ZBX_FONT_NAME value)
Please tell me the version of OS you are using and how to install Zabbix.
