Template Proxmox VE by HTTP: how to avoid restart alerts on VM (live) migration ?
  • beemo
    • Jun 2023
    I'm using zabbix 7.0 (upgraded from 6.0), after updating proxmox (cluster 8.2.5) and upgrading the Proxmox VE by HTTP template to 7.0 on zabbix.
    I'm trying to avoid getting reboot alerts when I migrate a VM from one cluster node to another, even though it's a simple live migration.
    I understand the logic, since the alert is based on uptime < 10 Minutes, and the VM has just been migrated (live migration no reboot) to another cluster node, so the alert is triggered.
    Is there a trick with the template in version 7.0 allowing me to do this through my action, and thus avoid restart alerts when it's a live VM migration ?
    Thanks in advance​
    • 4997
    Probably under operations... set the start after 10m (or even 11m) instead of immediately.. Then the problem should be gone before action fires and you do not get notifications... but it will affect any other event also, which falls under this action...
    • beemo
      • Jun 2023
      cyber , thanks for the answer but i don't know what to do with it, i still need alerts for my server in case of "real" reboot not in case of a change of cluster node which is detected as as uptime < 10 minutes.
      I ll wait for an integration of a solution Template Proxmox VE by HTTP may be one day...
