Can zabbix use a CDP to build network map like Cisco network Assistant?
  • gordeev
    • Feb 2017
    Hello to all.
    Does Zabbix support a CDP, or maybe there is a plugin to build such maps? I searched over forum and figured what answer is "no", but maybe i am just do not search hard enough? Are my point what zabbix only support manual network map drawing are correct?
