Good afternoon!
I need to create a triggers queried JMX where it validates every 1 hour if the value is greater than the previous one.
Example:
5000 >= 5001 OK
5000 = 5000 Failure
The value (5000) is incremented every minute, if it stops incrementing it is a failure.
Example:
5000 >= 5001 OK
5000 = 5000 Failure
