Error in calculated check item.
  • mudit.gupta
    • Aug 2016
    • 39
    Hello All
    I have created an item using calculated check but I am getting below error :
    Item configuration :::
    Name : % free on root
    Type : Calculated
    Key : free.root
    Formula : 100*last("vfs.fs.size[/,free]",0)/last("vfs.fs.size[/,total]",0)
    Type of information : Numeric float
    Units : %
    This item status shows Error :: Cannot evaluate function "last(0)": item "Ubuntu-Client 10.0.4.32:vfs.fs.size[/,free]" does not exist.
    May I get some help ?
    Mudit Gupta
  • Semiadmin
    • Oct 2014
    • 1626
    IMHO, there is extra "0" in your formula. The right one:
    100*last("vfs.fs.size[/,free]")/last("vfs.fs.size[/,total]")
    But... may be just use vfs.fs.size[/,pfree] ?
    • mudit.gupta
      • Aug 2016
      • 39
      Hello Semiadmin
      I have removed extra "0" and used ::
      but same Error :: Cannot evaluate function "last(0)": item "Ubuntu-Client 10.0.4.32:vfs.fs.size[/,free]" does not exist.
      Tried also :: 100*last("vfs.fs.size[/,pfree]") / last("vfs.fs.size[/,pfree]")
      Error :: Cannot evaluate function "last()": item "Ubuntu-Client 10.0.4.32:vfs.fs.size[/,pfree]" does not exist.
      Please help me , any one .
      Mudit
      • mudit.gupta
        • Aug 2016
        • 39
        Dear All
        Please help me on below mentioned issue.
        Mudit
        • mudit.gupta
          • Aug 2016
          • 39
          Dear all members ,
          Hope you all are fine.
          I am facing issue with calculated check , can you please help me in this ?
          Mudit
          • glebs.ivanovskis
            • Jul 2015
            • 237
            Error message says it all:
            Items you use in calculated item formula must exist!
            • mudit.gupta
              • Aug 2016
              • 39
              Dear glebs.ivanovskis
              Can you please explain it more "Items you use in calculated item formula must exist!" ?
              Mudit
              • glebs.ivanovskis
                • Jul 2015
                • 237
                Which part of it don't you understand?
                In your case you need to have item "vfs.fs.size[/,free]" on host "Ubuntu-Client 10.0.4.32".
                • mudit.gupta
                  • Aug 2016
                  • 39
                  I have created an item but still same error , please have a look at the attachment and suggest me, if anything is wrong .
                  Mudit
                  • dimir
                    Zabbix developer
                    • Apr 2011
                    • 1080
                    "Calculated" item works on an existing other item:
                    • I have item A
                    • I create Calculated item B, that uses item A
                    In your case item A is "vfs.fs.size[/,free]" and it is missing.
                    More information can be found here.
                    • kloczek
                      • Jun 2006
                      • 1771
                      BTW using this calculated item is completely pointless as long as zabbix agent on side of vfs.fs.size[/,free] provides vfs.fs.size[/,pfree] which returns in % free space.
