Postgresql Monitoring by Zabbix Agent2 Template for PostgreSQL16
  • Min Tun
    • Sep 2024
    Hi everyone,
    I saw the official documentation of PostgreSQL by Zabbix Agent2 supports for Postgres Version 10-15. https://git.zabbix.com/projects/ZBX/...at=release/7.0
    Is this template usable for PostgreSQL 16? If not support, how could I do for PostgreSQL16 monitoring?
  • Answer selected by Min Tun at 03-10-2024, 03:18.
    Min Tun
    • Sep 2024
    Yes it works well with PostgreSQL16. I just updated the template from latest release of version 7.0-0
    And here's the commands I run for PostgreSQL-Plugin installation and configuration.
    sudo apt update
    sudo apt install golang
    go version
    tar xvf zabbix-agent2-plugin-postgresql-7.0.3.tar.gz
    mv /home/appadm/zabbix-agent2-plugin-postgresql-7.0.3 /etc/zabbix/
    cd /etc/zabbix/zabbix-agent2-plugin-postgresql-7.0.3/
    make
    make check
    ls
    chmod 755 /etc/zabbix/zabbix-agent2-plugin-postgresql-7.0.3/zabbix-agent2-plugin-postgresql
    nano postgresql.conf
    >> update postgresql.conf with following content
    Plugins.PostgreSQL.System.Path=/etc/zabbix/zabbix-agent2-plugin-postgresql-7.0.3/zabbix-agent2-plugin-postgresql
    cp postgresql.conf /etc/zabbix/zabbix_agent2.d/
    chmod 644 /etc/zabbix/zabbix_agent2.d/postgresql.conf
    >>Includ the conf path in zabbix_agent2.conf (check the following line)
    Include=/etc/zabbix/zabbix_agent2.d/*.conf
    systemctl restart zabbix-agent2
    tail -f /var/log/zabbix/zabbix_agent2.log
      • 5008
      I doubt there is a big difference from monitoring perspective, is it 15 or 16... Andit is not said, it is supported on those versions, it says "has been tested on .. " Theres a difference..
      • zabbixuser39393
        • Jan 2021
        • 38
        It works with psql 16 (well, at least with zabbix agent)
        • Min Tun
          • Sep 2024
          sudo apt update
          go version
          make
          make check
          ls
