Zabbix 7.0.2 on Ubuntu 20.04
  • Mattéo45
    • Sep 2024
    • 18
    Hello everyone,
    I'd like to know if it's possible to install the latest version of Zabbix on an Ubuntu 20.04 VM. It's our production VM and I started with Zabbix 5.4 which I upgraded to 6.0 at first without any problems.
    But when I want to install version 7.0 nothing happens, I noticed on the official website that the “zabbix-server...” (file 1 and 2) is not available in 20.04 but the .deb package does exist in the directory... (file 3)
    I also noticed that after attempting to upgrade the pgsql, apache and php packages, they remain in version 6.0.33 (file 4). After starting the Zabbix server, the database doesn't update and zabbix is still running in v6.
    Do I really need to upgrade the VM to 22.04?
    Thanks for your help
    (sorry for the browser and cli in french language) ​​
  • Answer selected by Mattéo45 at 02-10-2024, 16:57.
    cyber
    • 4997
    20.04 will not work for v7. You need to upgrade.
    release.deb does not have to contain all the same for all platform versions..
      • 4997
      • Mattéo45
        • Sep 2024
        • 18
        Ok thanks for the quick reply
        It worked during the beta, so I thought it was still possible.
