Zabbix Agent2 - Template: How to connect to MSSQL Named instance
  • mike_a
    • Aug 2024
    Hi all,
    Has anyone had success monitoring a SQL Server named instance? I've tried adding each specific server name, along with the service name, but no luck.
    The MSSQL.URI I've tried to use is: sqlserver://localhost\<named instance name>:<port number>
    I also replaced local host with the instance (e.g. sqlserver://db-test\test01:1433)
    The Zabbix agent error I receive is: Get Value from agent failed: cannot establish TCP connection to <IP>:10050 timed out
  • Brambo
    • Jul 2023
    • 256
    My experience is use either the /instance OR port number not both. Maybe that helps (my instance has it's own port so using both fails)
    • mike_a
      mike_a commented
      Thanks for the feedback! I tried, but we also use a non-default port #. I've tried variations of <server>/<instance> for the URI, along with <Server>:<port>, but no luck.
