DEL Idrac used space monitoring
  • Jeff54
    • Jul 2024
    • 25
    Hi everyone,
    I am trying to monitor a DELL Idrac and i'm able to receive the size of physical disks and volume with the regular template.
    But I would like to see the used space on each of them (in Bytes and percentage)
    I tried to modify key on the item but I can't display the data.
    The original is just :
    DiskSize.[#Disknumber]
    Here is some of my attempts :
    DiskSize[#Disknumber,used]
    DiskSize.size[#Disknumber,used]
    But I always get the total size of the disk
    And I tried with the percentage fonction pused and the result in not realistic (95264682% or something like that)
    Did someone has a solution or an idea of the key that I can use ? Is it possible to do it this way ?
    Thanks and regards.
    Jeff
  • Julianna Wilamowska
    • Oct 2024
    • 34
    Hi Jeff, hope this can be of help to you.
    https://git.zabbix.com/projects/ZBX/...ell_idrac_snmp
    • Jeff54
      • Jul 2024
      • 25
      Thanks for the link Julianna, I tried with the physical and virtual disk size keys indicate but I have the same results.
      Yes jwolff, the type of info is in Numeric (unsigned) and with the B unit, I also have the custom multiplier parameters define with 1048576 to convert.
      I change it when I check in percent but I will focus on the B result first.
      I will continue to search but if you have other ideas I'd be interested
      Jeff
      • swpyatt
        • Jul 2024
        The iDrac template does not collect the OID for the space used. It does have physicalDiskCapacityInMB in the template giving the disk size. It does not have physicalDiskUsedSpaceInMB in the template. You could manually add it.
        • Jeff54
          • Jul 2024
          • 25
          Hi swpyatt,
          Thanks for your answer, I already saw it and tried to use it but a simple snmpwalk give me the same results that the Disk capacity.
          My disks aren't full, I doubt that the MIB return the correct value.
          And that's why I would like to use the native OID in the template and to change the key inside.
          If you have an other idea
          Jeff
