Can't upgrade from 6.4 to 7.0
  • db_owner
    • Dec 2023
    I'm not sure what I'm missing but the upgrade instructions don't seem to work for me. After installing the new repo the latest version found is still 6.4.
    user@zabbixvm:~$ rm -Rf /etc/apt/sources.list.d/zabbix.list
    user@zabbixvm:~$ wget https://repo.zabbix.com/zabbix/7.0/debian/pool/main/z/zabbix-release/zabbix-release_latest+debian12_all.deb
    --2024-10-15 14:20:48-- https://repo.zabbix.com/zabbix/7.0/debian/pool/main/z/zabbix-release/zabbix-release_latest+debian12_all.deb
    Resolving repo.zabbix.com (repo.zabbix.com)... 178.128.6.101, 2604:a880:2:d0::2062:d001
    Connecting to repo.zabbix.com (repo.zabbix.com)|178.128.6.101|:443... connected.
    HTTP request sent, awaiting response... 200 OK
    Length: 8096 (7.9K) [application/octet-stream]
    Saving to: ‘zabbix-release_latest+debian12_all.deb’
    zabbix-release_latest+debian1 100%[=================================================>] 7.91K --.-KB/s in 0s
    2024-10-15 14:20:48 (146 MB/s) - ‘zabbix-release_latest+debian12_all.deb’ saved [8096/8096]
    user@zabbixvm:~$ sudo dpkg -i zabbix-release_latest+debian12_all.deb
    (Reading database ... 41002 files and directories currently installed.)
    Preparing to unpack zabbix-release_latest+debian12_all.deb ...
    Unpacking zabbix-release (1:7.0-2+debian12) over (1:7.0-2+debian12) ...
    Setting up zabbix-release (1:7.0-2+debian12) ...
    user@zabbixvm:~$ sudo apt install --only-upgrade zabbix-server-mysql zabbix-frontend-php zabbix-agent
    Reading package lists... Done
    Building dependency tree... Done
    Reading state information... Done
    zabbix-server-mysql is already the newest version (1:6.4.19-1+debian12).
    zabbix-frontend-php is already the newest version (1:6.4.19-1+debian12).
    Skipping zabbix-agent, it is not installed and only upgrades are requested.
    0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
    user@zabbixvm:~$ sudo apt install --only-upgrade 'zabbix*'
    Note, selecting 'zabbix-sender' for glob 'zabbix*'
    Note, selecting 'zabbix-proxy-sqlite3' for glob 'zabbix*'
    Note, selecting 'zabbix-sql-scripts' for glob 'zabbix*'
    Note, selecting 'zabbix-java-gateway' for glob 'zabbix*'
    Note, selecting 'zabbix-server-pgsql' for glob 'zabbix*'
    Note, selecting 'zabbix-release' for glob 'zabbix*'
    Note, selecting 'zabbix-proxy-pgsql' for glob 'zabbix*'
    Note, selecting 'zabbix-apache-conf' for glob 'zabbix*'
    Note, selecting 'zabbix-agent2-plugin-mssql' for glob 'zabbix*'
    Note, selecting 'zabbix-server-mysql' for glob 'zabbix*'
    Note, selecting 'zabbix-agent' for glob 'zabbix*'
    Note, selecting 'zabbix-proxy-mysql' for glob 'zabbix*'
    Note, selecting 'zabbix-agent2' for glob 'zabbix*'
    Note, selecting 'zabbix-web-service' for glob 'zabbix*'
    Note, selecting 'zabbix-nginx-conf' for glob 'zabbix*'
    Note, selecting 'zabbix-frontend-php' for glob 'zabbix*'
    Note, selecting 'zabbix-agent' instead of 'zabbix-sender'
    zabbix-agent2 is already the newest version (1:6.4.19-1+debian12).
    Skipping zabbix-java-gateway, it is not installed and only upgrades are requested.
    Skipping zabbix-proxy-mysql, it is not installed and only upgrades are requested.
    Skipping zabbix-proxy-pgsql, it is not installed and only upgrades are requested.
    Skipping zabbix-proxy-sqlite3, it is not installed and only upgrades are requested.
    Skipping zabbix-server-pgsql, it is not installed and only upgrades are requested.
    Skipping zabbix-web-service, it is not installed and only upgrades are requested.
    zabbix-agent2-plugin-mssql is already the newest version (1:6.4.19-1+debian12).
    zabbix-apache-conf is already the newest version (1:6.4.19-1+debian12).
    zabbix-release is already the newest version (1:7.0-2+debian12).
    zabbix-sql-scripts is already the newest version (1:6.4.19-1+debian12).
    • 4985
    Your OS version? Either it is old enough and 7 will not run there... or it selects some other repo over official zabbix one and takes packages from there..
    • germanStar
      • Jun 2024
      apt list --upgradable | grep 'zabbix'
      Check whether zabbix server upgradable or not due to your os version and current repo
