Multiple triggers in an items
  • kitikant
    • Oct 2024
    • 29
    Hi everyone,
    I use Zabbix 7.0 LTS on Centos 9 stream.
    I have connected Zabbix to monitor my IPO device and it seems to work well. However, there are some items in my IPO alarms which contain multiple events, so an item can receive different events. For instance, I have an item that receive SNMP trap from OID 1.3.6.1.4.1.6889.2.2.1.2.0.48 but this OID can receive many different sub-events as the picture below. Therefore, I have tried to find information about how to separate sub events into different triggers because each of them has different severity level. Could anyone give me some suggestion associated with this issue? I really appreciate every kindness.
Name:	Screenshot 2024-10-17 162824.png
ID:	492892Click image for larger version
Name:	Screenshot 2024-10-17 170445.png
  • Answer selected by kitikant at 12-11-2024, 06:49.
    cyber
    • 4949
    Create triggers based on finding ipoGTEventStdSeverity value.. One for each severity... and for Event name extract that AlarmDescription from data...
    • kitikant
      kitikant commented
      Thank you so much for your suggestion. It works!
    • 4949
    • kitikant
      kitikant commented
