Value Mapping not working?
  • Bubbagump
    • Sep 2021
    • 18
    I am sure I am screwing up a data type somewhere but I can't figure where. This is on 7.0.4. I have an item that runs a Perl script to check if SIP is available. The script output either has '200 OK" in it or any other number of errors.
Name:	Screenshot 2024-10-18 at 2.23.34 PM.png
    Then I want to do a value map.
Name:	Screenshot 2024-10-18 at 2.23.51 PM.png
    However when I look at latest data, I get a 1 or 0 and the Value Map doesn't apply. What am I missing?
  • kyus
    • Feb 2024
    • 203
    Hey! After creating your value mapping, have you selected it in the "Item" tab when configurating your item?
    • Bubbagump
      • Sep 2021
      • 18
      That's it! I had it set to Text and that option wasn't offered. Set to Numeric and voila. THANK YOU! Sheesh.
      • kyus
        kyus commented
        I'm glad it helped! ​​​​​​​
