How to combine elements (items) into one "item group"
  • Przemek52o
    • Oct 2024
    I would like to create "stacked" / grouped items. Optical explanation in the appendix. My screenshots are gone, so I painted what I'm talking about now.
    i using this feature in zabbix 5.0, in 6.0 this desapeard.
    Is it still not available (in version 7.0)? I can't find information about it in the documentation and other materials.
    Or it has been replaced by another function?
Name:	Bez tytułu.png
    In my opinion, this view (under the “latest data” tab) is more responsive than the current one, and you could wrap up unimportant information or expand on, for example, a specific group of created items
  • Answer selected by Przemek52o at 03-11-2024, 20:34.
    cyber
    • 4996
    I dont remember old versions that well any more.. and I skipped 5 at all... But I think it was grouping based on "application". As applications as such are completely dropped (I think from v6), then its not really possible to group by it... Applications were replaced by tags, so you can do your selections based on tags in filter. In a way it is less stress to your DB, if you plan ahead your query and do not select all and then just visually hide some of it..
      • 4996
