SNMP will not activate?
  • sverkel
    • Feb 2017
    Hi.
    I'm all new to zabbix and I just can't get it to accept my SNMP (it will not turn green) in the Hosts section. I can see the SNMP service is running in debian, but no matter what I do, I can not get it to work?
    Does anyone have some advice or might have an idea to some software i'm missing?
  • colin88
    • Dec 2016
    • 13
    Did you activate the StartSNMPTrapper option in the zabbix config file? The default value is 0. It should be set to 1.
    • chillyw13
      • Jan 2017
      • 14
      Having the same issue. I have it set to 1, but the SNMP is not green.
