Zabbix Agent - No Conifg Window
  • GuyTownsend
    • Oct 2024
    I am trying to install Zabbix agent on a Windows server (Intel Xeon, 64 bit), I have download the agent with the following options (Windows>Any>amd64>7.0LTS>No Encryption>MSI), the MSI runs fine but I dont get the configuration window to enter our Zabbix server information.
    Any ideas why this would be?
    Guy
  • Answer selected by GuyTownsend at 28-10-2024, 13:20.
    moooola
    • Jul 2024
    • 33
    Hello.
    When you select Windows > Any > amd64 > 7.0LTS > No Encryption > MSI, the link goes to the Agent2 Plugin installer, not the Agent2 installer. I can't find any MSI installers with [No Encryption] set among the ones provided.
    -> https://cdn.zabbix.com/zabbix/binari...ble/7.0/7.0.5/
    It's a hassle to extract the ZIP and configure and register the service yourself, so I think it's more realistic to use the OpenSSL version of the MSI installer and uncheck [Enable PSK] if it's not needed.​
    • GuyTownsend
      GuyTownsend commented
      Thanks Mooola!
  • galavichid
    • Mar 2021
    • 45
    You had an Agent installed already on that machine?
    • GuyTownsend
      • Oct 2024
      Nope, 1st install of the agent. No idea why this is the case
      • galavichid
        • Mar 2021
        • 45
        GuyTownsend, I have installed today Zabbix Plugins and seen the config window does not appear.
        Maybe its the same case?
        • GuyTownsend
          Yes this is exactly what I see (or not!)
      • moooola
        • Jul 2024
        • 33
        Hello.
