Issues with LDAP Group Retrieval via DUO Proxy in Zabbix
  • NotHugo
    • Oct 2024
    I'm currently configuring LDAP authentication for Zabbix, with DUO set up as an MFA intermediary using the DUO Authentication Proxy.
    When using the DUO Proxy, Zabbix successfully authenticates users (I get "login successful"), but none of the LDAP attributes—specifically User role, User groups, and Media type—are retrieved. They all show as "No Value."
    Tested connecting directly to the DC without DUO, and this worked as expected, with all attributes retrieved successfully.
    Some might suggest that DUO is the issue, but I have other services using DUO in a similar fashion, and they’re able to retrieve LDAP attributes without any problems.
    This behavior appears specific to Zabbix with the DUO proxy configuration.
    Has anyone successfully configured DUO to relay LDAP group and role attributes to Zabbix?
    Are there recommended configurations for DUO’s authproxy.cfg or Zabbix’s LDAP group pattern that ensure groups are retrieved?
    Any other potential troubleshooting steps I might have missed?​
  • freiheit
    • Dec 2022
    • 11
    I have this working, with Active Directory as the backend LDAP. Currently on Zabbix 7.0.5, but worked the same on Zabbix 6.4.x.
    [ldap_server_auto2]
    port=38902
    ssl_port=63602
    ikey=REDACTED
    skey=REDACTED
    api_host=api-redacted.duosecurity.com
    client=ad_client
    failmode=safe
    ssl_cert_path=/etc/letsencrypt/live/duoauthproxy.example.com/fullchain.pem
    ssl_key_path=/etc/letsencrypt/live/duoauthproxy.example.comt/privkey.pem
    exempt_primary_bind=false
    allow_unlimited_binds=true
    exempt_ou_1=CN=Zabbix LDAP,OU=Redacted,DC=Redacted
    Zabbix LDAP config:
    - Port: 38902
    - Base DN: OU=Redacted,DC=Redacted
    - Search Attribute: sAMAccountName
    - Bind DN: CN=Zabbix LDAP,OU=Redacted,DC=Redacted
    - Configure JIT provisioning: yes
    - Group configuration: memberOf
    - Group name attribute: CN
    - User group membership attribute: memberOf
    - User name attribute: givenName
    - User last name attribute: sn
    - Media type mapping: Name:Email(HTML), Media type: Email(HTML), Attribute:mail, create enabled: yes
    - StartTLS: yes
