template_bind_stat: does it work for you?
  • troffasky
    • Jul 2008
    • 631
    bind 9.18
    Agent configured per:
    But none of the statistics work. Every parameter is returned as "null".
    # zabbix_get -k bind.queries.jq[cache,A,http://127.0.0.1:8053/json] -s dnsserver
    null
    No error in agent log.
    If we break down an item...
    UserParameter=bind.queries.jq[*],curl $3 2>/dev/null | jq ".$1.$2"
    Test on server:
    # curl http://127.0.0.1:8053/json 2>/dev/null | jq ".cache.A"
    null
    So agent returns exactly what command outputs. Fine.
    So command must be wrong. What is the correct command?
  • troffasky
    • Jul 2008
    • 631
    Don't know where I got cache,A from, that is not an item in this template. QryAuthAns is one of them, and it doesn't even exist in the JSON stats output! So no change to how this is queried will make that appear.
    • troffasky
      • Jul 2008
      • 631
      I guess I might have misunderstood how this worked. The JSON output was massive so there were loads of parameters available to monitor.
      But the parameters in the Zabbix template seem to have started working the moment I pointed some live traffic at this DNS server! So looks like some fields are not even present until the values are non-zero. Not what I was expecting.
      This appeared after server is serving live requests:
      # curl http://127.0.0.1:8053/json 2>/dev/null | grep QryAuthAns -i
      "QryAuthAns":1,
      And yet there are still hundreds of parameters with 0 values, which do appear. Go figure!
      # curl http://127.0.0.1:8053/json 2>/dev/null | egrep ':0$|:0,$' | wc -l
      359
