proxy compile fails
  • v.q
    • May 2013
    • 9
    proxy compile fails
    I try to compile zabbix proxy on Raspbian but it fails.
    From github sources I checkout tag 3.2.3, run bootstrap.sh and configure. All succeeds but make (without install) fails. Compiling an agent works fine.
    ./bootstrap.sh
    ./configure --enable-proxy --with-openssl --with-net-snmp --with-sqlite3 --with-ssh2 --with-openipmi --with-libcurl --with-libxml2 --sysconfdir=/etc/zabbix --datadir=/usr/share --datarootdir=/usr/share --libexecdir=/usr/libexec/ --bindir=/bin --sbindir=/sbin
    Configuration:
      Detected OS:           linux-gnueabihf
      Install path:          /usr/local
      Compilation arch:      linux
      Compiler:              gcc
      Compiler flags:         -g -O2
      Library-specific flags:
        database:                  -I/usr/include
        libXML2:               -I/usr/include/libxml2
        Net-SNMP:               -I/usr/local/include -I/usr/lib/arm-linux-gnueabihf/perl/5.20/CORE -I. -I/usr/include
        OpenIPMI:              -I/usr/include
        libssh2:               -I/usr/include
        TLS:                   -I/usr/include
      Enable server:         no
      Enable proxy:          yes
      Proxy details:
        With database:         SQLite v3.x
        WEB Monitoring:        cURL
        SNMP:                  yes
        IPMI:                  yes
        SSH:                   yes
        TLS:                   OpenSSL
        ODBC:                  no
        Linker flags:               -L/usr/lib    -L/usr/lib/arm-linux-gnueabihf -L/usr/lib -L/usr/lib -L/usr/lib   -L/usr/lib/arm-linux-gnueabihf -rdynamic
        Libraries:                  -lsqlite3 -lxml2    -lnetsnmp -lssh2 -lOpenIPMI -lOpenIPMIposix -lssl -lcrypto   -lcurl -lm -ldl  -lresolv
      Enable agent:          no
      Enable Java gateway:   no
      LDAP support:          no
      IPv6 support:          no
    *            Now run 'make install'                       *
    *            Thank you for using Zabbix!                  *
    *              <http://www.zabbix.com>                    *
    make
    make[2]: *** [all-recursive] Error 1
    make[1]: *** [all-recursive] Error 1
    make: *** [all-recursive] Error 1
    Please help.
    Regards,
    Vitali
  • Atsushi
    • Aug 2013
    • 2028
    Please check the output when executing make.
    A message should be output as to what was the error.
    You can also download the source of the release version in the tar.gz format from the download page.
    http://www.zabbix.com/download
    • v.q
      • May 2013
      • 9
      Thank you very much.
      Had to run "make dbschema" before running "make" or "make install".
