Trigger Help: SNMP OID item error "noSuchName"
  • abassillo
    • Nov 2024
    Hi All,
    Zabbix newb here.
    I am trying to trigger when an item snmpgets "nosuchname" (I am not trying to trigger snmp availability)
    I have an APC UPS that has a modular network card. When that network card is not communicating fully with the UPS, I will be able to snmpget some OIDs but not all. I currently have a trigger for when SNMP availability is down completely but I am trying to create a trigger when one specific OID returns a (noSuchName) error to let me know it's in this in-between state. It doesn't seem like I can apply any functions against null keys, I have tried things such as count but the trigger just fails because there is no value for the item. Can anyone advise how to trigger when a specific item's OID in SNMPGET is not retrievable?
    The item I am trying to trigger is showing "SNMP error: (noSuchName) There is no such variable name in this MIB."
    Thanks!
    That error is not an item value, so you cannot build a normal trigger to catch it... But there are "internal actions", which allow notifications, if some or other item turn to "not supported" state.
    • ISiroshtan
      • Nov 2019
      • 324
      From description it sounds like an SNMP query type of monitoring, right? So I would expect for data to normally be coming on specific predefined intervals, like once per minute or per 5 minutes, or whatever, right? Then why not just add trigger of nodata() type with double or triple interval?
