Can 7.0x proxy be newer than server?
  • jjeff123
    • May 2022
    • 35
    We have a proxy running 7.05 and a server on 7.03. Is that acceptable?
    I think only the major version matters (https://www.zabbix.com/documentation...sion%2Cversion)
    and so far my proxy is reporting in just fine.
    Just want to be sure before I start unleashing a bunch of updates.
    To be fully compatible with Zabbix 7.0, the proxies must be of the same major version; thus only Zabbix 7.0.x proxies are fully compatible with Zabbix 7.0.x server.
    I would say it is OK.
    • jjeff123
      • May 2022
      • 35
      Answering my own question, as far as I can tell there is no issue. Ran it this way for a couple days, have since updated server to 7.05
