Closing a problem raised through LLD created item/trigger automatically
  • abockhold
    • Apr 2024
    • 14
    I created a LLD rule which finds all logs for a backup process in a specific directory. These logs and the corresponding backups are deleted automatically after some time. The LLD rule creates an item for each backup and saves the state (succesful/unsuccesful). A trigger fires if unsuccesful and raises an incident.
    As said the backups and log files get deleted after some time. How can I automatically close an incident if the underlying log file got deleted?
    The item prototype:
    The trigger prototype:
    Thanks!
  • ISiroshtan
    • Nov 2019
    • 324
    In discovery set "Keep lost resources" to 0. This way when discovery will no longer detect previously discovered log file the item and trigger for said file will be delete - also deleting all alerts caused by it.
    But, if you have any notification integrations, I believe it will not send recovery notification. As problem would not actually be resolved, it would be just deleted.
    • abockhold
      • Apr 2024
      • 14
      Thank you very much!
