Dashboard issue width
  • duncan9562
    • Jan 2017
    • 46
    Hi all,
    In the Dashboard, the "Last 20 Issues" widget works great, however the Issues column restricts the output of the data received from the Item/Trigger.
    Example:-
    Item returns "CRITICAL: md1 failed [U_]"
    This is confirmed by latest data received from the host.
    The Issue column in Last 20 Issues is populated with "Raid CRITICAL: md1 failed...", and is not displaying the full output.
    I can inspect the element in chrome, and it shows the column cell as being populated with "Raid CRITICAL: md1 failed...". If I change that to "Raid CRITICAL: md1 failed test test test test test test" then that value is shown correctly.
    Does anyone know how I would go about increasing the value in the cell, so it displays the entire output and not a cut down version?
    Thanks in advance....
