Top hosts by network bandwidth?
  • sterling
    • Nov 2024
    The "Global Dashboard" in a new Zabbix 7 install has a widget that lists top hosts by CPU utilization. I'm wondering if there is any way to do this for network usage? The problem I see is my hosts all have different names for network interfaces, and there is no default aggregation available. Is there any way to do this?
Name:	Screenshot 2024-11-08 at 12.22.10 PM.png
  • ericg
    • Apr 2023
    • 15
    +1 I've got the same hurdle to overcome and am in need of this feature too. Either I'm blind, which I know I sure can be, or there is no simple way to make this happen.
      This widget lists by identical item names, so if your item names are all different (probably created by dscovery), then you are out of luck here..
