Urgen help required :(
  • yolkie
    • Feb 2017
    • 10
    Ok I have installed gnutls "yum install gnutls" while trying to figure out how to configure encryption between agent and server
    And then I uninstalled gnutls "yum remove gnutls"
    And my Zabbix server died.
    WEB UI is accessible but it is prompting me
    "Zabbix server is not running: the information displayed may not be current."
    Zabbix server is running: The value is set to NO
    Anyone have any advice?
  • batchenr
    • Sep 2016
    • 440
    zabbix server logs please..
    • yolkie
      • Feb 2017
      • 10
      As attached is the log.
      2269:20170222:151321.833 [Z3001] connection to database 'zabbix' failed: [1045] Access denied for user 'zabbix'@'localhost' (using password: NO)
      2269:20170222:151321.833 database is down: reconnecting in 10 seconds
      How can I troubleshoot this?
      Thank you for replying.
      • batchenr
        • Sep 2016
        • 440
        restart mysql - check mysql_error.log or any mysql log.
        try to connect to DB as zabbix user see if you can connect
        • yolkie
          • Feb 2017
          • 10
          I can only see this mysqld.log as attached.
          I can connect using zabbix user
          [root@zabbix etc]# mysql -u zabbix -p
          Enter password:
          Welcome to the MySQL monitor. Commands end with ; or \g.
          Your MySQL connection id is 246
          Server version: 5.6.35 MySQL Community Server (GPL)
          Copyright (c) 2000, 2016, Oracle and/or its affiliates. All rights reserved.
          Oracle is a registered trademark of Oracle Corporation and/or its
          affiliates. Other names may be trademarks of their respective
          owners.
          Type 'help;' or '\h' for help. Type '\c' to clear the current input statement.
          mysql> show databases
          -> \g
          | Database |
          | information_schema |
          | zabbixdb |
          2 rows in set (0.00 sec)
          mysql>
          • batchenr
            • Sep 2016
            • 440
            Enter password:
            owners.
            -> \g
            | Database |
            | zabbixdb |
            mysql>
            look at similar issue - see if it helps do all that we suggested there :
            • yolkie
              • Feb 2017
              • 10
              Dear batchenr,
              Thank you for trying to help. I have reinstalled the server from scratch as this is a new production server. Got it up back in about 1 to 2 hours.
              Thank you again! I have learnt more about zabbix through your post in another thread.
              • yolkie
                • Feb 2017
                • 10
                Now, I need to figure out how to do encrypting... ill do a backup first this time, before any changes
