How to configure Zabbix with reverse proxy and HTTP authentication
  • jose1711
    • Jun 2022
    I placed Caddy server in front of a Zabbix instance, configured to add an authorization to headers so that it passes Admin credentials (user appears logged in all the time):
    # zabbix default Admin credentials
    header_up Authorization Basic QWRtaW46emFiYml4
    Zabbix is configured to allow HTTP authentication and yet when vising https://zabbix.domain.com/index_http.php I am given and error message "You are not logged in - Login name or password is incorrect.".
    Is there something I am missing?
    Thank you,
    jose​
  • jose1711
    • Jun 2022
    Not sure if this is the best solution but I simply added the parameter to Nginx configuration, i. e.:
    #/etc/nginx/conf.d/nginx.conf
       location ~ .php$ {
        fastcgi_param  REMOTE_USER      Admin;
