Zabbix 6.5 yum repo
  • rsokolovs
    • Nov 2024
    Zabbix 6.5 yum repo
    I have Rocky 8 servers where I installed https://repo.zabbix.com/zabbix/6.5/r...el8.noarch.rpm some time ago
    Today when I ran dnf update zabbix-agent2 it failed:
    Zabbix Official Repository - x86 64
    GPG key at file:///etc/pki/rpm-gpg/RPM-GPG-KEY-ZABBIX-A14FE591 (0xA14FE591) is already installed
    The GPG keys listed for the
    "Zabbix Official Repository - x86_64" repository are already installed but they are not correct for this package.
    Check that the correct key URLs are configured for this repository.. Failing package is: zabbix-agent2-7.0.5-rc1.release1.e18.x86_64
    GPG Keys are configured as: file:///etc/pki/rpm-gpg/RPM-GPG-KEY-ZABBIX-A14FE591
    The downloaded packages were saved in cache until the next successful transaction.
    You can remove cached packages by executing 'dnf clean packages'.
    Error: GPG check FAILED
    It was trying to install 7.0.5-rc1.release1.el8
    When I checked https://repo.zabbix.com/zabbix/6.5/rocky/8/x86_64/ it contains 7.0 alpha beta and RC versions.
    It seems that this is some kind of bug of zabbix repo.
    And after upgrading zabbix-repo package to https://repo.zabbix.com/zabbix/7.0/r...el8.noarch.rpm everything updated correctly.
    it is not a bug.. you first installed a development version of 7.0. which had repo number 6.5. By now 7.0 is ouf officially, you should reinstall from official 7.0 repo. https://repo.zabbix.com/zabbix/7.0/rocky/8/x86_64/
    • rsokolovs
      • Nov 2024
      I don't know why we installed zabbix-release from version 6.5, but it still seems to me strange that in 6.5 versions repo you can get 7.0 version.
      And GPG check failed for those packages
        as I said.. 7.0 dev version were in 6.5.. it has always been like that with zabbix... for 6. it was 5.5 I think etc... those official versions are "even", x.0, x.2, x.4, those in between (odd) are dev versions...
        You wanted to install 7, did not notice that its still in beta, addded repo for it, which actually points to a version 6.5.... nothing mystical
        • rsokolovs
          • Nov 2024
          OKay, maybe you are right
