Powershell script why return a json object?
  • Spamme
    • Feb 2017
    Hello, I'm new to zabbix and I have to monitor an application on a windows server, therefore I need a powershell script. I was checking some examples in internet and some of them return a json object:
    But the "type of the information" in the zabbix item can be only:
    • Numeric (unsigned)
    • Numeric (float)
    • Character
    • Log
    • Text
    Why returning a json object if zabbix cannot handle them?
    Do I miss something?
  • Atsushi
    • Aug 2013
    • 2028
    Perhaps, I think that the script that outputs the result in JSON is a script for low level discovery(LLD).
    By using this function, you can monitor things that change the number of objects to be monitored depending on the status with one setting.
    Manual:
    • Spamme
      • Feb 2017
      Uhm, it could be correct because one script lists the available drivers and the other one the services and their state. But aren't those discovery functions (most probably scripts) already available in Zabbix?
      In any case this could be the reason, why those scripts return a json object and not a single value.
