Ever since some updates, a few zabbix agents (still version 5.0.44) are failing to connect with ssl-related errors.
Trying to make Zabbix-agent and server communicate between two hosts, but the zabbix-agent host is using gnuTLS, which is much more particular than openssl;
I even tried setting the SAN properly, to no avail.
Anyone know more details in particular about 'what' could be wrong with the cert?
In the web interface, I see:
Zabbix agent on trap647.coyote.com.au is unreachable for 5 minutes
I've properly flipped around (inverted) the TLS Subject string, and changed EmailAddress to EMAIL as wanted by GNUtls. It used to work; It's configured like this on the client in zabbix_agentd.conf (any identifiable information has been changed in this example, it's a ficticious value but should get the point across):
On the client:
On the server:
TLSServerCertIssuer = [email protected],CN=zabbixca.acme.com,OU=Sysadmin,O=ACME,L=Melbourne,ST=Victoria,C=AU TLSServerCertSubject = [email protected],CN=zabbix.coyote.com.au,OU=HQ,O=Wiley Enterprises,L=Strzelecki Desert,ST=NSW,C=AU
On the client:
/usr/sbin/zabbix_agentd --version | grep GnuTLS Compiled with GnuTLS 3.7.1 Running with GnuTLS 3.7.1 tail -n 1 /var/log/zabbix-agent/zabbix_agentd.log 2479919:20241112:102954.051 failed to accept an incoming connection: certificate subject does not match for 88.88.88.88
cat /etc/hosts | grep zabbix.coyote.com.au 88.88.88.88 zabbix.coyote.com.au openssl x509 -text -in server.crt -noout Certificate: Data: Version: 3 (0x2) Serial Number: 3f:de:5e:21:a4:72:c4:0e:0e:17:6a:7d:89:24:8f:07:e1 :56:b1:ac Signature Algorithm: sha256WithRSAEncryption Issuer: C = AU, ST = Victoria, L = Melbourne, O = ACME, OU = Sysadmin, CN = zabbixca.acme.com, emailAddress = [email protected] Validity Not Before: Nov 12 09:03:38 2024 GMT Not After : Nov 12 09:03:38 2027 GMT Subject: C = AU, ST = NSW, L = Strzelecki Desert, O = Wiley Enterprises, OU = HQ, CN = zabbix.coyote.com.au, emailAddress = [email protected] Subject Public Key Info: Public Key Algorithm: rsaEncryption RSA Public-Key: (2048 bit) Modulus: 00:ac:99:8f:1c:30:96:6f:56:b0:dc:a7:05:54:16: 17:50:c5:7d:5b:59:80:6d:6b:93:63:8c:36:38:f2: ee:30:8b:89:9a:85:42:ce:58:62:4c:08:88:f5:15: 06:33:ef:48:68:08:8c:af:79:57:ec:1b:33:60:a7: 59:83:4c:ee:85:7f:48:c6:a3:0d:f0:1d:a0:2c:6e: af:65:74:bf:00:24:89:c4:48:3d:62:39:14:72:32: 3b:5a:a0:df:ba:d9:8e:42:a5:a9:73:f4:81:f1:b2: eb:c7:a6:86:2f:db:6d:e2:9c:00:75:78:c9:f3:a4: e6:3d:99:9a:81:75:7a:ba:78:02:7d:86:c3:a5:93: e4:0a:be:e5:2b:fb:e1:87:36:03:f1:36:c2:9f:67: f6:f2:27:09:24:36:88:ff:4d:eb:03:d0:6c:90:a6: e1:56:38:a4:2b:ba:9c:8d:4d:41:43:08:35:db:72: eb:d7:b5:12:1f:d7:f6:b3:b3:05:40:a0:25:28:63: 00:0c:5c:3c:ba:37:45:13:03:b1:df:02:51:a4:d1: da:d9:23:0c:b7:53:73:27:b7:cc:83:bb:50:4a:40: 68:9c:d4:55:38:af:d9:71:38:7f:b0:0e:ea:04:c1: fc:1f:70:b3:c4:0a:b7:37:e5:ba:a6:5a:be:e1:b1: 48:f1 Exponent: 65537 (0x10001) X509v3 extensions: X509v3 Subject Key Identifier: F4:7A:1A:3D:12:76:5D:DE:79:6A:59:6D:0E:14:CD:CD:45:EF:7C:21 X509v3 Authority Key Identifier: keyid:9E:F2:28:9B:32:F5:18:34:25:94:E6:3E:0E:DC:00:BB:83:CA:AF:5F X509v3 Basic Constraints: CA:FALSE X509v3 Key Usage: Digital Signature, Key Encipherment X509v3 Extended Key Usage: critical TLS Web Server Authentication, TLS Web Client Authentication X509v3 Subject Alternative Name: DNS:zabbix.coyote.com.au, IP Address:88.88.88.88, IP Address:2008:8007:BEE9:BEE9::12A Signature Algorithm: sha256WithRSAEncryption 4a:ab:cc:87:b3:55:f4:2c:0d:ae:18:12:7b:d0:ee:d3:07 :58: c7:a5:5d:c7:cd:db:cd:1c:fe:60:2c:75:aa:22:81:8b:d5 :5f: 69:3b:a0:00:a3:53:77:d7:7b:77:46:8c:16:4e:6a:4b:67 :8c: c6:4d:3c:6d:3e:48:04:36:cf:c2:89:95:34:17:50:21:60 :8b: 33:a7:ec:75:b0:62:12:dd:b9:6d:21:27:80:d2:49:dc:09 :80: 50:40:11:51:ea:84:03:03:7a:b9:59:23:6a:f9:07:28:7f :41: 6c:70:1f:ff:66:b2:31:6a:a3:e5:28:b1:eb:f2:e4:a2:f1 :6c: fd:62:b2:51:93:c6:d0:58:72:ba:0a:42:51:af:b1:2b:ff :15: f7:87:3e:c9:47:21:74:36:e8:0f:a3:e6:e5:34:30:68:ee :bd: 26:72:d8:15:02:de:fd:18:43:8a:02:0d:b2:f3:4d:30:8f :68: 02:e5:e1:2e:53:0a:78:4f:d1:33:9b:3b:8a:60:51:59:10 :ae: 70:22:50:e3:2e:cf:97:ab:22:45:2d:5b:57:b1:bc:99:b6 :a1: 06:b8:b1:69:48:d6:4c:5c:84:10:f8:02:0e:c5:7d:0f:dd :b7: f4:86:89:a4:c3:e8:ae:fe:75:b4:5a:32:95:2a:90:a9:db :86: de:87:9b:2d:d9:06:32:11:1a:92:0c:e2:cc:63:c1:c3:eb :ce: 1b:1e:18:37:86:79:28:93:c2:aa:15:91:e0:b3:58:b0:43 :48: ab:4b:6e:15:98:6c:4f:03:c0:09:14:9d:dc:5a:b0:73:1f :a4: 54:1d:92:9d:21:a1:ed:56:78:01:19:7b:1d:a3:24:38:1b :3c: d0:96:79:4c:54:bf:bc:aa:2e:ed:bf:6b:99:99:9f:2e:1c :60: 5d:2f:8c:a3:e0:a7:04:80:e8:d4:8e:5a:2f:28:fa:c2:14 :8b: c4:82:76:77:66:61:c6:07:77:60:38:88:4b:0d:9e:99:18 :08: 6c:2f:b3:cf:ff:e9:8e:0e:f3:fa:00:1d:58:e8:df:f9:6e :c9: b1:50:2d:1f:fd:36:25:e6:3b:2b:fe:e3:b7:18:4a:44:e3 :64: f1:35:92:ad:33:d0:5d:41:12:c9:31:f7:24:0b:fd:fe:1e :97: 71:d3:e1:e3:61:bb:72:03:a4:b6:5b:18:38:a3:12:3b:79 :33: 56:e4:17:be:46:55:21:29:4f:d8:3e:4a:93:af:4f:e6:75 :a7: cc:98:19:de:85:b7:5b:88:97:40:c4:7c:72:96:ed:02:70 :3d: 8d:65:e2:fa:f6:ee:2a:2f:a7:08:2d:3a:ad:99:ea:4f:14 :ff: 8a:90:7b:3e:80:80:09:ab
