Add Link to Webinterface in Widget "Honeycomb"
  • Nalo
    • Aug 2024
    I use the Widget "Honeycomb" in my dashboards.
    Is it possible to add a link in the widget, to access the Webinterface from the device?
  • Nalo
    • Aug 2024
    Does anyone have an idea?
    • Brambo
      • Jul 2023
      • 250
      In honeycomb this isn't possible as far as I know. Maps support links and you can add a map to a dashboard.
      However visually a map isn't a honeycomb
      • Nalo
        • Aug 2024
        Thank you for rour reply. I hope the feature will come in the next versions...
