Issues with simple trigger conditions
  • JoePhillips
    • Jul 2024
    Hi All,
    Wondering whether somebody can help me... I have a SNMP check that returns a text value of "00 00 00 00" when it's status is OK. If any values change in "00 00 00 00" there is a problem and I would like a trigger to occur so I am notified.
    I have configured the following problem condition where if the string value does not equal "00 00 00 00"
    last(/Alcatel SNMP Virtual-Chassis by Joe Phillips/vcmissing2.slot)<>"00 00 00 00"
    Along with the following recovery condition where the string value does equal "00 00 00 00"
    last(/Alcatel SNMP Virtual-Chassis by Joe Phillips/vcmissing2.slot)="00 00 00 00"
    However the a problem is being triggered constantly even though its reporting back with a string value of "00 00 00 00". Any help would be greatly appreciated!
    last()<>"string"...
    If we look on trigger expressions...
    <> Not equal. The operator is defined as:
    A<>B ⇔ (A<B-0.000001) or (A>B+0.000001)
    Doesn't fit ,right?
    use
    find(/host/item,,"like","00 00 00 00"))<>1
    and you do not need recovery expression there, as it is exatly same as main expression being false, which anyway turns your trigger to OK already...
    • JoePhillips
      • Jul 2024
      Hi Cyber,
      Thanks for taking the time to reply. I’ll give your suggestion a try tomorrow
      • JoePhillips
        • Jul 2024
        Hi Cyber,
        Just to update you, your suggestion worked a treat (minus one bracket)! Thanks very much, really appreciated the help there.
